RCU Forums - View Single Post - SET UP
Thread: SET UP
Old 12-02-2009 | 11:18 AM
ricomari
Default RE: SET UP
Robert, thanks for the quick reply. I'm confused. I was planning on using the two outputs from the SuperReg to connect to the receiver Batt port and an empty port. I don't understand about havng a connection for every two servos ( "4 connections into the receiver from the regulator"), there are only two outputs on the SuperReg. Will this regulator not support/feed the receiver with the two output with all the servos plugged into the receivers . Sorry for my confusion, I'm sure it's simple and I'm just not grasping it. Henry
