RCU Forums - View Single Post - Need quick answer - correct powerswitch wiring?
Old 12-02-2009 | 02:59 PM
atkleiv's Avatar
atkleiv
Default RE: Need quick answer - correct powerswitch wiring?
ORIGINAL: taoJ
Looks correct to me, all your doingis interupting positive voltage , a simple meter test should show you open and closed positons, if you have those then your good to go, if you dont have a meter, hook up your batt and a motor to the output side of the switch and see if you can control the motor on/off via the switch.
Thanks, I was in doubt about this because I was told that it works with this other method also (see picture):
