RCU Forums - View Single Post - Need quick answer - correct powerswitch wiring?
Old 12-02-2009 | 03:12 PM
dyeager535
Default RE: Need quick answer - correct powerswitch wiring?
Darkith posted in the thread you linked about cutting the ground to reset some of the electronics. I got the impression it's not likely necessary most of the time.
A lot easier/simple to use the switch as you've wired it.
