RCU Forums - View Single Post - Need quick answer - correct powerswitch wiring?
Old 12-02-2009 | 04:54 PM
dyeager535
Default RE: Need quick answer - correct powerswitch wiring?
As Darkith posted:
"Basically, the electronics positive pole is the center pin of the switch. Slid one way, it gets positive power from the battery. Slid the other way, it connects the electronics positive pole to the electronics negative pole and drains the capacitors. Note that because the battery is on the end pole, it can *only* be connected to the electronics, so things will never be shorted. "
