RCU Forums - View Single Post - Graupner Hawk build thread
Old 12-03-2009 | 08:04 AM
steverobertsuk
Default RE: Graupner Hawk build thread
Ok advice needed.
I'm looking to fit the small doors which will cover the retract body when shut.
The problem I have is how to hinge it and what linkage and linkage position I should use.
I was thinking of a flat plate Kavan style hinge but because of the double skinned door I'd have to try and cut a slot into it for the hinge to fit. Ideas????
Also is there an easy way of working out the geometry of the linkage rather than trial and lots of error!??????
I guess that the easy option is to just fit the door on to the leg with a spacer but I'm not sure if it would look right as the full size seems to have this little door sitting a reasonable distance from the leg once opened.
Easier still would be to just leave them off completely but Simon is a bit of a perfectionist [:@]
Steve
