RE: Effect of too much nose weight
Elevator control is weak throughout the flight, and the plane fights you on turns and loops. A nose heavy plane wants to go straight, and the faster you go the stronger the tendency is. As mentioned above, a nose heavy plane likes to drop its nose when going slow, hence the faster landing speed. You know you have the CG right when the plane just does what you tell it to at any flying speed above stalling.
