RCU Forums - View Single Post - Boomerang Sprint Build Thread!
Old 12-03-2009 | 04:19 PM
  #1029
kmw072671
Default RE: Boomerang Sprint Build Thread!
Hi,
I'm getting ready to install the control horns and was thinking about using Tam Jets control horns just like R/C Gypsy did - hysol them in one side of the hard wood of the control surface. My concern is will this be strong enough since the horn will only be glued tothe hardwood on the underside of the control surface and not glued or connected to the the hard wood on the top side of the control surface?
Or, maybe I should just get some good control horns that screw through the top and bottom hardwood surface like Alan intended....
What sayith you....
