RE: Minimum voltage to safely fly
I just did a little more research at TBM site and it pretty much agrees with Fromeco's info that NO FLY voltage is 7.0 Volts under a 1amp load, but goes into more detail. Here's what it says (I've bolded some of it):
- When a 2-cell pack reads 6.8v under a 1 amp load on a new pack, it has no capacity left.
- When a 2-cell pack reads 6.9v under a 1 amp load on a new pack, there is about 25% of the capacity left.
- Each 15 minute flight on an average 35% airplane uses about 400 mah. This offers 12 flights on two 2-cell packs. When you test the batteries and they show 6.9v, you have enough battery life for a few more flights, but don't do it!!
Be safe. When either battery reads 6.9v (or higher), stop flying and recharge.
Again, with a 1 amp load, I'm going to stop flying when I get down to 7.0V. I'll charge before each day's flying and should be set for the day. Of course, I'll check voltage under a 1 amp load between flights to make sure I don't get down to 7 volts.
