RE: Minimum voltage to safely fly
to be on the safe side follow manufactures recommendations..... My 7.4 5200 mah packs are 8.3 or so volts fully charged If you charge them friday night you should be able to fly a lot .. Since i dont have a one amp load,( i think the its a 250 mah load built in my volt meter) i stop flying at 7.2
Check them after every flight for a few flight sessions to better assess your batteries..
