RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 12-03-2009 | 10:09 PM
  #99
MTK
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: apereira
My YS160 used to turn the 17x12 at 8200RPM the same RPM the OS160 was making on a friend of mine airplane, but the OS even dough had the same top RPM it had probably 40%less power from idle to about 80% power, of course he bought my engine and dumped the OS, so this is about torque not just top RPM.
Pattern planes flying with OS and engines alike are usually handled like an on/off switch it will not pull a solid vertical unless they are at full power.
So the Syssa might have more torque, and making comparisons at top RPM with other engines are not fair, I think this engine will be better than the currently available gassers as it's being modified with pattern flying in mind.
Have no present intention of modifying my engine. If we decide to make changes later, I will probably discuss it here.
It occurred to me that one of the best 2 stroke engines for all around handling ease was the older style YS60 so called short stroke (the 61 long stroke came a couple years after and never ran as sweet for me). We simply stretched the pipe and ran big loads
The Syssa 180 is reminiscent of that experience...but enough hyperbole. I need to generate numbers
MattK
