RE: Robbe Type XXI And The Cats Meow
She is finished !
A few days ago I finaly shipped her off in a huge wooden crate to California and with a sob she went onto the UPS truck.She was fun to build and runs so well and majesticly.
The pics show the aft sections acsses that very good on this sub .Notice the the green cannon plug it makes an easy water tight connection to the mating plug for all of the circuits ,2 ESC s and one light circuit a total of 6 wires done with marine grade 16 gage wire of variuse colors for easy identification.
The wire with the silicone tube on it is actualy 2 the hot pos and negative wires that directly charge the main battery,since the batery runs in the wet it can be charged without having to open up the sub,nice!When turned on the wires are no longer hot so that if ever water gets to them electrolisis will not ocure.Also easy readings can be made of state of charge extra can be made along with the LED voltage gage I inmstall in all of my subs.This gage can be seen threw the limber holes at the stern while in the water also so that one can always have easy remaining power reading.
Just seperate the two wires and connect via wire clips and your ready.
The vid is not to clear butat least the operation canbe seen.
