RE: YS-170CDI Flight Report
<span class="long_text" id="result_box"><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Boa tarde Pessoal," onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">Hello Guys,
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Voltando da pista de aeromodelo, vamos ao que interessa:" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">Returning, let's get to my report:
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="1 - A primeira coisa que tentei foi remover a parte de baixo do cowl e tentar voar com ele com a refrigeração máxima." onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">1 - The first thing I tried was to remove the bottom of the cowl and try to fly the Osmose with the maximum cooling. </span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Mas no ultimo voo da semana passada eu e uns amigos tinhamos mexido no regulador eo problema não foi mas o apresentado para vocês nas threads anteriores, agora quando chega em 5400 rpm ele morre e notei que esta saindo muito combustivel pela check valve no cabeçote do motor" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">But in the last flight in last week me and some friends we had change the regulator and the problem change, not more is the presented to you in previous threads, now when the engine reach 5400 rpm it stops and I see that the fuel in check valve in head engine </span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="(numero no manual F4088 n.85);" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">(number in the manual F4088 n.85) spits so much fuel;
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="2 - Tentei colocar uma bateria de 1450 mah;" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">2 - I tried to put a battery of 1450 mah for the ignition;
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Estou enviando videos que relatam quando o motor chega em 5400 ele morre e se voces notarem sae muito combustivel pela check valve quando ele chega perto desta rpm e morre depois." onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">I am sending videos in the youtube that report when the engine go to 5400 rpm and stop and a lot of fuel in the check valve.
[youtube]http://www.youtube.com/watch?v=cuGN-eQ31iI[/youtube]
[youtube]http://www.youtube.com/watch?v=rV7TQLtikVw[/youtube]
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Conto com a ajuda custumeira de todos voces e gostaria de saber:" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">Thank you for the usual help of all of you and would like to know:
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Qual é a configuração de fabrica dos parafusos do regulador, agulha de alta e Sub Agulha?" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">What is the factory setting in the regulator screws, high needle valve and the Sub Needle valve (with this answers I believe that I back to my original problem)?
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Muito Obrigado" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #fff">Thanks
</span><span onmouseout="function onmouseout(){this.style.backgroundColor='#fff'}" title="Douglas" onmouseover="function onmouseover(){this.style.backgroundColor='#ebeff9' }" style="BACKGROUND-COLOR: #ebeff9">Douglas</span></span></p>
