RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 12-05-2009 | 04:50 PM
griesel
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
I hooked up the right slider to the CAMBMIX which was neat. The ailerons would move
up (spoilerons) or down ( flaperons ) just by rotating the slider. However during regular
flying I was continually bumping the slider causing the camber to change and then
the trim would change. I finally disabled this feature. It would be better to have
another switch enable or disable this feature or use a 3 position switch instead of the
slider.
