RCU Forums - View Single Post - Assembly Question: FMS Sky Trainer
Old 12-05-2009 | 10:54 PM
blvdbuzzard
Default RE: Assembly Question: FMS Sky Trainer
No glue required for the wing. I put mine together 3 days ago. You slide the carbon spar into one wing half, slide the other wing half onto the spar. Put the wing in place, tighten the two screws in the trailing edge.
Seems to work pretty well.
I did strip out the set screw that holds the steering arm onto the nose wheel strut. I ended up slotting it and putting in a hex nut. Now it holds very well. I will end up making a new arm out of brass.
The glue that comes with the ARF works pretty well. I used it for the tail parts.
Dru.
