RCU Forums - View Single Post - Neptuno 170
Thread: Neptuno 170
Old 12-06-2009 | 09:40 AM
roalddogge
Default RE: Neptuno 170
ORIGINAL: riot3d
A) Lower the servo tray inside the stab more. Presently, the linkage is not quite in line with the servo arm, it's on a slight angle. I have to shim the connector with washers
Heee Adrian,
Instead of using shims, why not use that alu thingy you put on the outside of the the ball bearing link instead in between the link and horn ? ;-)
When will the rest be ready ? Should take no more than 2 days.....hahahaha
