RCU Forums - View Single Post - Neptuno 170
Thread: Neptuno 170
Old 12-06-2009 | 10:36 AM
riot3d
Default RE: Neptuno 170
ORIGINAL: roalddogge
ORIGINAL: riot3d
A) Lower the servo tray inside the stab more. Presently, the linkage is not quite in line with the servo arm, it's on a slight angle. I have to shim the connector with washers
Heee Adrian,
Instead of using shims, why not use that alu thingy you put on the outside of the the ball bearing link instead in between the link and horn ? ;-)
When will the rest be ready ? Should take no more than 2 days.....hahahaha
I did switch it.
I don't install as fast as you guys. Since this is their first with two ele servo, I had to do a lot of trial fitting to make it work, I should have the rud done by tonight. As long as I don't have to keep answering your questions ...
BTW, aren't you suppose to be busy looking for a phone for a certain young lady? ...
