RE: How to convert an ATX power supply to rc use
I need some help with my AT conversion.Powers up and works fine with no load.Voltage measures 10.8 volts.Added two 10 Ohm 10 Watt resistors in series to the 5 volt side and brought the voltage to 11.76.Do i need to change to a different Ohm resistor to get above 12 volts?
