RCU Forums - View Single Post - lancair ailiron problems
Old 07-15-2003 | 10:49 AM
MMallory
Default lancair ailiron problems
CKS,
If you use the side mounts, make sure the wood blocks are attached to a clean wood surface and not the foam (unless they are supported on 2 or more sides). I sometimes will install a thin ply plate first to strengthen the balsa skin for these mounts.
Mark
