RCU Forums - View Single Post - Picked the plane...now the electronics?
Old 12-07-2009 | 12:16 AM
ChuckW's Avatar
ChuckW
Default RE: Picked the plane...now the electronics?
The 15C should be fine. You only have a 30 Amp ESC and the 15C, 2200mAh battery will provide 33A. I doubt the stock motor and prop pull that much. The burst C-rating on the batteries is likely even higher. I still might go for 20C's though since they might be better suited if you get any other planes where the current demand is higher.
