RCU Forums - View Single Post - Neptuno 170
Thread: Neptuno 170
Old 12-07-2009 | 04:16 AM
riot3d
Default RE: Neptuno 170
One of the challenge of installing two ele servo on the stabs is to snake the extension leads through the fuse. Even though, the factory has pre-installed a paper tunnel inside the fuse for the leads, but the inside diameter is always so narrow making it a time consuming job. Hopefully, in the future, the factory will leave a string inside the paper tunnel for us to use as a lead line for the extension cords.
Rudder cable installation is pretty straight forward, and Jet Legend did provide us with cables. However, I have been using the IM rudder cable for the past two years with good results, it's a bit easier to set up than the Du-Bro 4/40 kit. Again, factory has pre-installed two ny rod inside the fuse for the cable, making installation a snap.
Now that ele & rud is done, time to move on to the engine, header, pipe & cdi installation.
ID:	1328968   Click image for larger version
ID:	1328969   Click image for larger version
