ORIGINAL: scott09
ORIGINAL: apache 56
hay guys is it worth me buying a evo top end kit and new piston/ring.. and placing on to a zenoah bottom end..
as i have a near new stock zenoah sitting around. or go for a hole new rcmk evo..????....
Would like to know this too. I have an air g23, can I just use the $89 evo top end and have a much better engine?
Is the g23 2 bolt.??????? Air cooled engines bolt the source coil to the cylinder, you will not be able to mount the source coil for lack of mounts for it on the water cooled jug. ??????
