ORIGINAL: avconslt
Bentley,
I finally had a chance to install the Nutech diff in my FG Stadium truck, and I seem to be having a problem with the handling of the truck ever since! I filled the diff up with 50,000 diff fluid as recommended and all seems well with the diff install, except that when I accelerate it wants to pull quickly to the left, and when I let off the gas it seems to want to turn quickly to the right! Can anyone explain why that might be, and do you think the new diff causing it? I have checked the rest of the running gear and all seems normal! Thanks.
Richard
i didnt realy have a prob with my marder ...... prob a silly question but have you checked your wheel alignment ?? give it a little more tow in and try it ..see if that helps... allso check that your masurment from front wheel center to rearwheel center is the same
