RE: Starter trouble
If your sure it not low battery voltage, did you change the rubber cone? It may be worn, and not grabbing the spinner or nut you are using. Clean the rubber cone with alcohol wipe it down and , try it again. If it's an issue with the starter, contact Hobbico, they will help you.
