RE: Ugh 27% edge go bye bye
[&:][&:][&:]jstickley, Here's YAK building right now and 99.9% done. Just have finish Radio Set Up on My 2.4 JR9303[sm=surprised.gif][sm=75_75.gif][sm=shades_smile.gif] My Flying Partner Don building 100CC Richmodel Extra 260. Here's Specs on My New YAK. Specifications:
Wing Span:2210mm(87″)
Wing Area:1457 sq.in.
Fuselage:78″
Weight:15.5-16.5 lbs
Engine: 50cc gas
Wing: plug-in wing/stab
Cowl diameter: 10.25" at the fuselage.
C. of G is 6.5" from the leading edge by the fuselage.
Thank you for your consideration of our 30% YAK-54.
This Yak-54 was successfully recreated with the same characteristics the full-scale version is acclaimed and more!
With this Yak-54 and its silky smooth flight characteristics will take your stick inputs and translate them into a precise
choreographed routine. What this Yak-54 could do is flat spins, blenders, waterfalls, torque-rolls, elevators and harriers
which are all just in a days work with this Yak. Be sure this Yak-54 will make you proud when you fly it in the blue sky.
Few of the features of the Yak 54 ARF kit:
Kit is built entirely from laser cut parts, very precise fit of all parts makes this a strong and very light airplane.
Fuselage and wings are all wood built-up construction witch covered in genuine Ultracote Covering.
Plug-in wings and stab makes it easy to transport. Carbon fiber tubes used for wing and stab attachment.
Fuselage has built-in tunnel for different mufflers and pipe installations.
Very strong fiberglass cowl with reinforcement ring, extremely simple and effective installation system.
High quality canopy with pre-painted trim is a part of a huge removable hatch on top of fuselage,
provides with unrestricted access to all components of radio gear, fuel tank and wing attachment.
Finally! Some high quality hardware:
Machined Aluminum control horns.
Complete cut to length 4-40 rod set.
Swivel ball attachments throughout.
Complete Pull-Pull cable set-up.
Carbon Fiber tail wheel spring with complete hardware and aluminum horn.
Large fuel tank with straps, light wheel set also included.
This kit designed and built with 3D Flying in mind, huge control surfaces will provided with extreme maneuverability
while outstanding design of full size aircraft provides solid flying performance throughout flight envelops.
[:-][X(][&:]On Sale 20% Off Right Now. [sm=omg_smile.gif][sm=idea.gif][sm=thumbup.gif] I bought 2 for $422 each DELIVERED to My Door Complete. That's with Fed EX Ground Shipping. Best Quality ARF We have Built and had all Big Names, Hangar9, Aeroworks Etc. Just Idea for Xmas or in Future. AK-models is a Super Company to deal with. Alex is ACES!!! richgrow
