RCU Forums - View Single Post - What would your ideal R/C workshop look like?
Old 12-08-2009 | 12:40 PM
Bundubasher's Avatar
Bundubasher
Default RE: What would your ideal R/C workshop look like?
I doubt whether one will ever have an ideal workshop. When I started mine, I was still flying small planes, they have grown in size but the workshop stayed the same. It measures 3.5m by 4m. I'm using kitchen cabinet units which can be bought separately, re-inforce the bottom chasis and fit lockable castors so I can move it all around depending what I'm working on. I've fitted glass tops so I can put info , pics etc underneath whilst I can cut covering material and balsa on the glass - also build on it, just scrape the glass with a box knife blade to clean superglue, epoxy and paint off it.
I use upright wooden supports, drill holes in it, fit dowels in it and use it to store my wings.
My feather foam cutter is mounted on a pull out tray underneath the benchtop with the yellow/orange/red wing on it.
ID:	1329800   Click image for larger version
ID:	1329801   Click image for larger version
ID:	1329802   Click image for larger version
ID:	1329803   Click image for larger version
