I tried everything. Completely full new set of CVDs with new universal joints and pins, New C Hubs, New Bearings.
I tried 44mm Swing shafts, I am about to try my 42mm swing shafts. Hopefully the wheels will stop vibrating wildly when I turn. Hopefully. They don't seem to do it when the wheels are off though. WHen the wheels are off they "seem" to be normal I can full throttle nothing vibrates.
Here it goes. :/
Update: So tested the 42mm. Same thing. With the wheels off it's fine. Works great. I still have the rotor hubs on too so there is rotating weight when I tested it with the wheels off.
So I thought there was something wrong with the wheels. Misshapen, too much dirt in the wheels causing it to be off balance, weight difference or warping basically. I stuck on HPI rims with no tires and it's started vibrating like crazy again as soon as I started turning on my radio. It's starts half way down on the steering radius when I turn to test it. It runs smooth when it's running straight.
<span class="Apple-style-span" style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; ">
http://www.youtube.com/watch?v=vFcnOUJSX64
As you can see in the video, it runs fine straight. hen i turn it goes nuts.</span><br type="_moz" />
