RCU Forums - View Single Post - Flip 3D
Thread: Flip 3D
Old 07-09-2003 | 07:59 PM
Sailor
Default Flip 3D
If you have carbon fiber, then by all means use them, or at least use 4-40 rods.
For elevator or rudder servos, use something that has around 80oz/in torque like the Hitec 605's. Stardard servos will be fine for the ailerons.
You might want to glue the canopy with RC-56 canopy glue instead of screwing it on as mine cracked where the screws went into the plastic. I had to order another canopy and I glued that one in and it has been fine since.
One other thing, I actually drilled through the metal hinges and pinned my rudder and elevator as my rudder came loose after a couple of flights.
