RE: Black Magic VF3 Build Thread
Hi Jason,
what you actually do is trim the outside stab tube so it extends about 1/16 out on both sides of the fuse. once you align and spot glue the stab tube in place. lay the fuse on it's side and with 5 min epoxy fill the gap flowing the epoxy against the tube, once dry sand flush with a block and your done....
If you built a jig like mine, you can align the wing and stab tubes in the jig,
sounds like your making progress....
dean
