RE: YD-A 56 vs. DLE 55
Hi Jones...,
I was very concerned with the plastic block also, but I was assured that it was standard equipt. with these guys, and have been tested, tryed, and true...
Again, I broke the first one, so I am a little leary, as I like to tighten screws more than the plastic/rubber will allow, but I believe that it will get tight enough. Otherwise, I will make an aluminum plate to cover the reed block flange, but that is later, after the tests. I plan on doing a follow up of things that I want to change, and post the outcome of these changes, but again, that's later...
