Help with kill switch options
That should do it. If I used your diagram as a guide, I would want to cut the "+" wire between the existing switch and the ignition plug.
Also, it doesn't matter which wire I use coming out of tht RC-100 on the switch end or the module end. In other words there is no polarity. Thanks for the fast reply_bob
