RCU Forums - View Single Post - Sealing surface gaps
Old 12-09-2009 | 10:44 PM
KWJ48's Avatar
KWJ48
Default RE: Sealing surface gaps
Blenderm is the easiest way to seal gaps. I usually flex the surface to its full throw and then seal. You may have warped the hinges a little if you laid the iron on it too long causing some binding.
