RCU Forums - View Single Post - Sealing surface gaps
Old 12-10-2009 | 11:35 AM
ppkk's Avatar
ppkk
Default RE: Sealing surface gaps
I looked up Blenderm, interesting application for a surgical tape! I take it if Blenderm is being recommended, then others have successfully used it with glow planes. With that said, I still have to ask the question: is it fuel proof?
Also a question on application: how easy is it to move it around once applied? In other words, if not placed correctly, can it easily be removed and replaced or will it take off the covering with it?
Thanks again everyone for your responses. I do think that the covering may be interfering with the movement of the hinges, so I will remove just enough covering above the hinges to see if it helps.
