RCU Forums - View Single Post - Programing Aleirons as Flaps
Old 12-11-2009 | 06:46 AM
CGRetired's Avatar
CGRetired
Default RE: Programing Aleirons as Flaps
The debate that comes up about flaperons is that when used in that manner, you remove the effectiveness of the ailerons when you most need them to be fully operational. If you push in, say, 20 degrees flaps, that's 20 degrees less aileron control you have.
I would suggest that if you want flaps, them build them in, independent of the ailerons.
CGr.
