RCU Forums - View Single Post - Sebart Wind 110
Old 12-11-2009 | 05:49 PM
  #431
Velco's Avatar
Velco
Default RE: Sebart Wind 110
Well I can give you the exact weight for the larger ones I have:</p>
Rhino 6S 3700mAh 25C with 6mm bullet connectors: actual 597g, advertised 600g</p>
Turnigy 6S 3600mAh 30C with 4mm bullet connectors: actual 580g, advertised 577g,</p>
Rhino 4S 2250mAh 40C with 6mm bullet connectors: actual 248g, advertised 263g</p>
As you can see they are correct!</p>
Also I have just realized that Xoar is offering 18x9 3 blade E prop, and that might just do the trick with Scorpion 4035-250 on 10S.</p>
http://www.xoarintl.com/props/model-airplane/PJI-E.html</p>
