RCU Forums - View Single Post - TIGER 60 Build / Start date 12-05-09
Old 12-11-2009 | 07:09 PM
blvdbuzzard
Default RE: TIGER 60 Build / Start date 12-05-09
You could take a slot machine and cut a thin slot and put in a thin piece of carbon fiber. Wrap some carbon cloth and use some poly. Cut it out and replace with a carbon fiber rod, cut it out, fill the slot with balsa, slot for steel wire joiner.
Here are the mains from Tower. I also included the tri gear setup to compare.
http://www3.towerhobbies.com/cgi-bin...10W1&search=Go
http://www3.towerhobbies.com/cgi-bin...?&I=LXJZE4&P=7
I just like the looks of a tri gear setup. It is about as much work to get the nose gear in as both main gear though.
Dru.
