RCU Forums - View Single Post - Motor and esc recomendation
Old 12-11-2009 | 08:30 PM
telleslattari
Default RE: Motor and esc recomendation
<font color="#000033">hey guys?!</font> <div><font color="#000033">i really need to know </font><font size="+0" color="#000000" style="BACKGROUND-COLOR: #ffffff"><span style="FONT-FAMILY: Arial; COLOR: blue; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">bout the thinks i will buy if they're can work thogeter with no problems, battery, charger, motor...</span></font></div><div><font size="+0" color="#000000" style="BACKGROUND-COLOR: #ffffff"><span style="FONT-FAMILY: Arial; COLOR: blue; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">i wanna put all this in a boat that i made, it`s 37 inch and 650 g  about 1 m longer, not for competitiom only for fun, it`s a catamaran max cat 1, well, this things can work thoghether?</span></font></div><div><font size="+0" color="#000000" style="BACKGROUND-COLOR: #ffffff"><span style="FONT-FAMILY: Arial; COLOR: blue; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"></span></font> </div><div><font size="+0" color="#000000" style="BACKGROUND-COLOR: #ffffff"><span style="FONT-FAMILY: Arial; COLOR: blue; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">- motor</span></font></div><div><font size="+0" color="#000000" style="BACKGROUND-COLOR: #ffffff"><span style="FONT-FAMILY: Arial; COLOR: blue; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">3660SL 3060kv Brushless Inrunner (WaterCooled)
Kv: 3060rpm/v
Diameter: 40.30mm
Length: 75mm
Shaft diameter: 5mm
Weight: 299g
Battery: 2~3S 3,000mAh
</span></font></div><div>Standard size mounting holes enable the motor to be installed in a large range of motor mounts.</div><div> </div><div>- eletronic speed control</div><div>Turnigy Marine 35A Brushless Boat ESC
With an ultra fast CPU and USA power FETs, the Marine brushless esc is a high performance ESC capable of standard and competition use.
<span>Programmable settings;
Reverse
Low Voltage (none/2.6v/2.8v/3v/3.2v/3.4v)
Brake: (none/soft/hard)
Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)</span>
</div><div>
Constant Current: 35A
<span>Burst Current: 190A
Resistance: .0015 ohm
Battery: 2-3S Lipoly
BEC: 6v/ 1.5A
Motor Type: Sensorless Brushless
Size: 31.5 x 27.5 x 16mm
Weight: 32g</span></div><div> </div><div>- battery</div><div><font size="3">Turnigy 3000mAh 3S 40C Lipo Pack</font></div><font size="3"></font><div>Spec. Minimum Capacity: 3000mAh </div><div>Configuration: 3S1P / 11.1v / 3Cell </div><div>Constant Discharge: 40C </div><div>Peak Discharge (10sec): 50C </div><div>Pack Weight: 278g </div><div>Pack Size: 145 x 43 x 21mm </div><div>Charge Plug: JST-XH </div><div>Discharge plug: 4mm Bullet connector </div><div> </div><div>- charger/discharcher/balancer</div><div><font size="3">GT A-6 Charger/balancer/discharger</font></div><div>
Features;
Microprocessor controlled
Delta-peak sensitivity
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.</p>
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 580g
Dimensions: 133x87x33mm</p>
</div><div> </div><div>-servo</div><div><font size="3">Power HD Metal Gear Servo 60g/15.5kg/.16sec</font></div><div>Model: HD-1501MG
Voltage: 4.8~6.0v
Speed: 0.16~0.14sec
Torque: 15.5~17.0kg/cm
Weight: 60g
Size: 40.7x20.5x39.5mm</div><div> </div><div>- control</div><div><font size="3">Hobby King 2.4Ghz 4Ch Tx &amp; Rx (Mode 2)</font></div><div>-channel 2.4GHz transmitter with servo reversing.
Easy to use control for basic models.
Includes 6-channel receiver
Trainer system option.
This system does not need a PC to program servo direction.
<div><div>Included;
1 x 2.4Ghz transmitter
1 x 2.4Ghz Receiver
1 x Bind Plug.</div><div> </div><div>and this is my doubt - ubec or ibec?</div><div>does i really need?</div><div>which one?</div><div> </div><div>- ubec </div><div>hexTronik UBEC.
Will supply a solid 5v or 6v to your reciever with a  2 to 5S Lipoly pack.
Specifications;
Output: 5v/3a &amp; 6v/3a (Selectable via jumper)
Ripply: &lt;50mVp-p(@2A/12V)
Input: 5.5v~23v (2 to 5s)
Weight: 12.5g</div><div> </div><div>- ibec</div><div>iMAX iBEC 6A Linear Regulator &amp; Glow Plug Driver.
</div><div>Spec.
Input: 2 cell lipoly
Output: 5.3v BEC &amp; 1.4v for glow driver
max Current: 8A
max Cont. Current: 6A
Weight: 58g
</div></div></div><div>PLEASE CAN ANY ONE HELP ME?</div><div> </div><div>i live in brazil, this kind of hobby isn`t popular here, and i don`t know any one else who can help me on this doubts, i search somethig to read but did`nt find so much...</div><div>if does any one can help, please i`m waiting. </div><div>thanks leo</div><div> </div><div>ps, all this products are on this link:</div><div> </div><div> <u><font color="#0066cc">http://www.hobbyking.com/hobbyking/store/[email protected] m&amp;idCustomer=190844</font></u></div><div> </div><div>its my wish list on hobby kink,</div><div>only place that i`m allowed to buy...</div>
