RCU Forums - View Single Post - center of thrust
Old 12-11-2009 | 10:54 PM
Lnewqban's Avatar
Lnewqban
Default RE: center of thrust
Louis9624,
If the down thrust angle is like specified by the designer, it is possible that your middle wing model has a different problem than what you suppose.
If the CG is located too forward, you may be trimming the elevator up to compensate.
This may introduce a decalage for which your neutral model has not been designed.
That incidence difference between wing and tail may make it sensible to speed changes.
Just try a shallow dive with no engine and see if it noses up when it picks speed.
Check this link out:
http://www.charlesriverrc.org/articl...GMarkDrela.htm
Regards!
