RCU Forums - View Single Post - Motor and esc recomendation
Old 12-12-2009 | 05:35 PM
nick 30
Default RE: Motor and esc recomendation
im going with the kb 3670 (1400kv) 2x 3s, 3600 mah, 25c (constant discharge) everythings waterproofed and watercooled so hopefuly it will run fairly cool as i chucked the usual cooling pipes and putting in 3mm (inner diameter) cooling pipes, mite try it 1st with my 3s 2200mah batt's to see how she runs, when i'm down the lake i'll do a video and post it
like you rebuilder, i like to push it, that way i find out the limits, if it sinks, it sinks, i just start again, but i have found out that the setup should be ok, if not then i just move on
