RCU Forums - View Single Post - before going nuts on the color schemes...
Old 12-13-2009 | 09:30 AM
rcpattern
My Feedback: (45)
Default RE: before going nuts on the color schemes...
ORIGINAL: Ilikebipes
Hey everyone,
I am entering sportsman and will be flying the Ultrasport. It will be covered in Monokote- no paint, and powered with a Magnum .61 two stroke.
My thinking is I may need to alter the nose a little depending on setting the final thrust angle on the engine. I was thinking I may not want to finish everything if I need to cut it all out to reset the nosecone if I am unhappy with the factory specs.
This probably explains my post a little better as well.
Brian
I flew an Ultra Sport years ago, and the normal setup is really close. I wouldnt worry about adjusting the front for thrust. I honestly prefer the method of mixing rudder to wide open throttle for thrust adjustments anyway as it is problem specific, and is easier to change as you change props.
Arch
