RE: Looking for a real FAST plane!
Hi, If you really want fast get an old Top flite holey smoke and a os 46 ducted fan engiine and when you build the model cut out an extra rudder/fin and put both on the model about 5 inches apart so you will have twin fins then run the tuned pipe between them. this combination will yeild over 200 mph. Make the top and bottom of the model different colors or you will get confused and stick it in the ground. the kit is no longer made but can be found on ebay.
