RCU Forums - View Single Post - Can you put a .61 size engine in a .46 size plane?
Old 07-07-2003 | 10:52 AM
GRANT ED's Avatar
GRANT ED
Default Can you put a .61 size engine in a .46 size plane?
Well, possibly. I put a 61 MDS in a sport flier 40. This is an ARF and i didn't check the glue joints. The end result was the bulkhead an engine departed the plane after a high speed pass. I think if you check the plane out and maybe beef up suspect areas u should be ok.
