I am building a Tiger 60 (Deluxe). The Deluxe kit is not made anymore but Goldberg will still send the plans and die cut wood necessary to complete the mod for a small price. I have looked at many retract gear trying to decide which will be the most reliable and also not too expensive. Mechanical are the cheapest, but I decided to go with air up/ spring down. Or is it spring up/air down. Either way, they are made by Robart and you can get them from Tower for about 120 bucks for 2 mains. Only 1 servo required and you can mount it in the fuselage. The gear is activated by an air valve which is activated by the servo.
<font color="#00265e">http://robart.com/retracts/6-12lb510.aspx</font>
That is the link to Tower. Check it out. Just another option to look at if you havent allready picked up your gear.
