Hi!
My order number is 693472
The product I purchased was
http://www.nitroplanes.com/new204chathi1.html
I received it on time and all looks great. The shipment was super and the plane looks great. I am about to complete the assembly (I started the assembly a few hours after I received the package. No flights have been made as I still need to condition the batteries, set trim, etc...)
I have two issues. 1. The front landing gear (the steel wire) current angles do match the fittings to hook into the servo. It fit very snug and would not allow the front wheel to rotate in one direction. In the attempt to adjust it to fit, the top 90 degree angle developed a crack in the wire. I am wondering if I can get this replaced. I'll have to carve out a bit of space to get one to rotate the way it needs to move. :-( 2. The second issue is that whith the battery in the servos seem to freak out whith the Tx off. (about 60% of the time) I havent seen this much so I wanted to post it and ask if there could be a malfunction with the receiver.
Everything else so far looks great on the model and all other components operate in a test scenario. Ordering process, tracking, delivery were all superb. I'll be a much returning customer!
Any help would be greatly appreciated.
Thanks!
-Brent
