RCU Forums - View Single Post - When do you re-ring?
Old 12-15-2009 | 06:16 AM
pe reivers
Default RE: When do you re-ring?
If you wait too long before changing the ring, the bottom ring land will have worn too much, and a new ring will not have a proper seat. A new piston is due in that case.
Better to change the ring before it is worn too much. (max ring gap 1mm, which is about 0.15mm wear on the ring cylinder face)
