ORIGINAL: gkamysz
What is your application for this engine? Did you find the friction bearing to be unsuitable?
This will go into a Hangar 9 Stearman. Didn't want the plain bearing because of a body of knowledge out there that says needle bearings are less sensitive to normal oil fuel mix ratios.
