RCU Forums - View Single Post - NEW EVOLUTION CORE, FLYRCRIVESUD
Old 12-15-2009 | 07:21 PM
  #110
sonat
Default RE: NEW EVOLUTION CORE, FLYRCRIVESUD
ZERO BLADE STRIKE CORE, VERSION 2.0
FREE!!! 10 PCS FOR REVIEW
ADD YOUR NAME HERE
history of the beta version 1.0
we almost got it right, but it seem due of peoples having upgrade motor
we got trouble with version 1.0 our gear was bigger by 0.20mm and this cause friction because some brand of motor have also bigger pinon gear
THE NEW VERSION 2.0 ( ZERO BLADE STRIKE CORE )
got same spec as eflite gear ( same size )
we invested over $15,000 in mold, for the gear and shaft to be the best there is!!
with a extra 45mm between the upper and lower blade ( BLADE STRIKE WILL BE A THING OF THE PAST )
We hope that the version 2.0 will be ready for January 25/2010
add your name here, 10 CORE WITH BLADE GRIP V2.0 WILL BE OFFER FREE!!
WE ASK ONLY THAT YOU MAKE A FAIR REVIEW
AND ALSO THAT YOU KNOW YOU WAY IN ASSEMBLE THE PARTS ( EXPERIENCE!! )
We found out on version 1.0 that some had put the grip kit on, and did not install the washer
this cause a lots of wobble it took us a lots of time to find out that, this user forget to do a proper installation
LOW WEIGHT = MORE FLIGHT TIME!!
www.flyrcrivesud.com
