RE: Servo Compatability ? ? ?
Yes, they are compatible, I just made the switch myself.
You will need to trim the directional tab of off the Futaba servo, white is the signal wire.
I used a dremel to grind mine off, some people use side cutters, just whatever you are comfortable with.
Tim
