RCU Forums - View Single Post - When do you re-ring?
Old 12-16-2009 | 09:26 AM
pe reivers
Default RE: When do you re-ring?
Sport, That is the axial play of the ring you talk about. The dimensional wear I talked about is the radial wear. You can either measure it by ring end gap measurements by placing the ring in a part of the bore that does not wear, OR you can measure the ring cross section directly. For the latter measurement you need to know the dimensions of the ring when it was new (very often not known)
