RCU Forums - View Single Post - Seagull Decathlon
Old 12-16-2009 | 12:10 PM
nrad2000
Default Seagull Decathlon
I have been flying RC helicopters for almost 4 years. Both Nitro and Electric. I then got this strong desire to fly airplanes. I bought a used G3 simulator and practiced flying different model planes. Few weeks ago I decided on the Seagull Decathlon ARF. All the electronics are in, engine mounted, lines connected, and all i need now is fuel. I then learned on this RCUniverse that the Decathlon is not a Beginners plane. I am very determined to fly the Decathlon.
when they talk about balancing the plane what does that mean? should it balance so that the fuselage is parallel with the floor or the chord or wing incidence is parallel with the floor/horizon? manual saids to balance between 90 - 100mm. it will balance at 80 - it will balance at 120. of course the plane will look either too nose heavy or tail heavy.
Will the Magnum XLS 46 be enough to get her flying?
Hobby store suggested 11 x 6 prop. will that be ok?
Any helpful advice about the flying characteristics?
