ORIGINAL: MrCoffeeMax
No, if I'm not mistaken, the Seamaster was designed by Laddie Mikulasko (sp?) as a water version of his ''Schoolmaster'' or ''Headmaster'' design.
Thanks, i will look into that..
goirish,
what difference did adding the fins to the tail make if any? Did you fly it prior without them to see? I will be using a RCGF20cc gas on here, not sure if it will be enough or not. How does it do with the magnum1.80?
Shane
